Please tell me I am just over looking it.
I cannot figure out how to blank a single component in just one view. Has
anyone done this in WF 1.0?
Thanks for the help,
Brian S. Lynn
CAD Administrator/Designer
    brianlynn1-VisitorAuthor
    I have tried that, didn't work for me. I am using build M140 is there a
    bug with this build? I am also working with a detail view will that cause
    a problem?
    Brian S. Lynn
    Sure,
    It is under View, Drawing Display, Component Display. Once you select
    this, you get the menu manager with the old options.
    Michael Drum
    Engineering Business Analyst
    Rubbermaid/Irwin
    _____
    The answer is that detail views won't let you have a different component
    display than the parent. As a work around, I had to do was create a
    general partial view and fake the rest to make it look like a detail view.
    Personally I think that stinks, but then I am not writing the code just
    using it. Summaries follow below.
    Brian S. Lynn
