Point at center of curve?
Ok, in WF2 where did they put the place point at center of curve? I
found an earlier post but the answer posted did not work. I cannot find
the pulldown option "at center".
Thanks!
Gerald Lanz
    Choose "Center" from the hidden drop down menu (I'm not kidding) in the
    reference dialog box
    I can't find my screen-capture of it at the present time...
    -Brian
    I have an assembly model where the pulldown simply does not exist, nomatter what I do. Other models, it is there.
    M160
    Randy Speed
    President and CEO
    Speed Consulting, LLC
    (972) 938-0490 ph (972) 937-2319 fax
    www.speedconsulting.com
    I'll check. The "hole" is on a slightly curved surface. Does the surface have to be flat?
