Apr 30, 2010 10:16 PM UTC
Point WF5 to network Help files
Used to be an option in PTCsetup to direct Pro to look on a network share
for the Help files.not there now. Can you still do this?
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
    Sep 2, 2011 7:13 PM UTC
    How do I configure Pro/E WF5 (CEPro 5) to access help that is installed on a network share?
    I installed the help files to a network share, as I have done in Wildfire 3 and prior.
    In the past, I updatedconfig.pro setting
    20-Turquoise
    Sep 2, 2011 7:59 PM UTC
    Can't do that anymore...
    You have to install on a web server.
    This is very poorly documented starting on page 6-6 or 82 in the install guide.
    > In the past, I updated<install-point>\text\ptc_help.txt to point to the network location.
    > This is not working anymore.
    > Any attempt to display help in WF5 (CEPro 5) does nothing but pause for a few seconds.
    > The documentation mentions setting config.pro setting help_center_path to a web server. (such as
    Sep 6, 2011 12:13 PM UTC
    As Randy indicated, this is coverred (badly) on page 6-6 of the Creo install guide.
    One of the options is to install help on a web server.
    Well, I've got Windchill, which includes Apache & TomCat.
    So I ran the installer web_deploy.bat.
    However, this is not enough.
    The last install step says " Configure your Web server to distribute Help Center from the <servlet_document_root>\proe_help directory."
    Unfortunately, I do not know how to do to this with Apache/TomCat.
    Any advice?
    Gerry
    In Reply to Gerry Champoux:
