Jun 13, 2012 12:51 PM UTC
polygon
Good morning all
I may be wrong but I thought Proe once had a command for extruding a polygon (hex, octagon, etc). How do you now build a polygon?
Thanx
Paul
    Jun 13, 2012 1:01 PM UTC
    Basic polygons are available in Sketcher from the sketcher palette.
    Best Regards,
    Bjarne Frandsen
    Jun 13, 2012 1:04 PM UTC
    Before that, we'd make a construction circle and make the polygon inside
    that circle with the end points meeting at the circle. You could then
    make all the sides equal length and then put a dim across the flats to
    drive it.
