Port Maps and Member maps
Can anyone explain the difference or tell me where to get additional informaition on port maps and member maps?
I'm using RSDesigner 5.4
I currently create variable connectors and then assign the appropriate dataset to each.I currently have to change the properties of each port of every connector to assign the entry_port property.I am looking for a way to more easily do port assignments.
If i recall correctly from the minimal trainingI recieved, those two items are likely to ease my pain and help automate the proces a little more.
Nathan Gugliotti
