Jul 29, 2015 12:09 PM UTC
Preselection Toggle
Hi I am not able to find out how to toggle preselection display in Creo. Can anyone help me out?
    2-Explorer
    Jul 29, 2015 5:20 PM UTC
    File > Options > Selection
    Check/uncheck "Enable preselection highlighting".
    Mahesh_Sharma
    22-Sapphire I
    Jul 30, 2015 10:40 PM UTC
    Niyaz,
    Did the earlier reply help you?
    You can use config option prehighlight as yes/no.
    Aug 3, 2015 6:37 PM UTC
    Try this mapkey to see if it does what you want:
    mapkey ph @MAPKEY_NAMEToggles pre-highlighting\non and off.;\
    mapkey(continued) ~ Select `main_dlg_cur` `appl_casc`;~ Close `main_dlg_cur` `appl_casc`;\
    mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg`;\
    mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `Sel_prefs`;\
    mapkey(continued) ~ Activate `ribbon_options_dialog` `Sel_prefs.PrehButton`;\
    mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;\
    mapkey(continued) ~ Command `ProCmdSelFilterSet` 4;
