Jun 10, 2009 8:14 AM UTC
PRO/COMPOSITE
how to use PRO/COMPOSITE? which is the best about pro/composite and catia V5? thanks!
    Aug 9, 2010 8:30 PM UTC
    Is this a statement or a question? Please clarify.
    Apr 22, 2011 6:45 PM UTC
    FiberSIM is a dedicated engineering environment for composites that provides an end to end (conceptual design through in-service) solution. FiberSIM is a ProE intergrated environment, utilizing a master model approach for composite defintion, i.e. the composite definition is developed and stored in the .prt file.
    FiberSIM's key points are:
    1. Easy multiple ply defintion utilizing a common materials database
    2. Materials and manufacturing process specific simulations to properly assess material drapabiltiy - incl. deformation, deviaiton, steering
    3. Ability to interface with all leading composite CAE aplications
    4. Offset surface functionality based on thickness regions and core, assisting design engineers with solid part defintions
    5. 3D documentation such automated as cross sections
    6. Automated development of outputs required to support your manufacturing processes from hand lay-up to automated deposition
    Respectfully,
    VISTAGY
    Leigh Hudson
    Director of Product and Market Strategy, FiberSIM
    Jul 16, 2012 11:17 PM UTC
    Does it create a native Pro/E (Creo) model that can be used in an assembly and that represents the plies, core, etc. in a single model that retains each element's mass properties?
