Pro/E
Hi All my question is How can I make rotational cut or involve cut without using Involve option, just use the cut option. Thank you kourosh
    Insert -> Advanced -> Neck (Section must be open)
    Or use a sweep with a semi-circular or circular trajectory. You realize that the revolve feature does NOT have to go 360deg?
