pro/e student edition problem
hi, im having problem with pre-select highlight its suppose to highlight the edge or face on the extrusion but its not and how can you download parts if your using student edition. thanks
    Check to make sure the config.pro option prehighlight is set to yes. You can't open native parts that were created in the commercial version. You can open files such as STEP or IGES.
