Pro/Engineer Network Install vs Local installations
I've been asked to investigate the pros and cons of installing
Pro/Engineer and serving it from a network location versus installing it
locally for each user.
Can anyone point me in the right direction, or share their
experience/viewpoint?
Thanks!
Michelle McMasters
Black & Decker Hardware & Home Improvement
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
