Problem in changing the URL in Pro/E
Hi...
I need to change the Default browser setting when Pro/E launches.
I have tried to find from option, but unable to get the same.
Please help me if anybody is having answer of it,
Thanks ....
Thats
Amit
    Browser settings govern by following options:
    1.web_browser_homepage
    2.windows_browser_type
    3.enable_3dmodelspace_browser_tab
    These can change option from the tools->option.
    You can change these as per requirement.
    Niraj
    amitshah1-VisitorAuthor
    Hi Niraj,
    Thanks for your reply.
    The URL got succesfully changed, it is unable to connect from Pro/E.
    My internet connection is working fine.
    I have also tried to load different pages,but the problem is same.
    Is there any other setting I need to check or change.
    Regards
    Amit
    Hi Amit,
    There is no other setting for this.
    Are you getting any error while connection?
    Can you tell me in eralier case, is it going to www.ptc.com site?
    You have probabaly done it correctly but still check that you have entered the URL correctly
    lets say www.google.com against the value.
    Niraj
