8-Gravel
Jul 16, 2015 6:59 AM UTC
Problem in Integration of Creo 2.0 with Matlab 13 Simulink
I am facing a problem while integrating the matlab with creo 2.0.
I have successfully completed the steps that are required to start Simulink in Matlab.
While adding the registry file in creo 2.0 gives me the error as shown in the screenshot
Please help me out if any body knows the solutions for this.
i have tried for all different versions i.e Pro/e 4, Creo 2.0, and Creo 3.0.
If possible also share some better solution to do this
Jignesh
    Jul 16, 2015 11:33 AM UTC
    can you show us the contents of protk.dat file ?
    Martin Hanak
    jvadalia8-GravelAuthor
    8-Gravel
    Jul 18, 2015 5:28 AM UTC
    the content of the protk.dat file is as follows:-
    name SimMechanics Link
    startup dll
    exec_file C:\Program Files\MATLAB\R2013a\bin\win32\cl_proe2sm.dll
    text_dir C:\Program Files\MATLAB\R2013a\toolbox\physmod\smlink\cad_systems\proe
    end
    Jul 18, 2015 1:59 PM UTC
    at the following page I have found some information
    http://www.mathworks.com/help/physmod/smlink/ref/linking-and-unlinking-simmechanics-link-software-with-proengineer.html
    The general contents of protk.dat is:
    startup dll
    exec_file matlabroot\bin\os\cl_proe2sm.dll
    text_dir matlabroot\toolbox\physmod\smlink\cad_systems\proe\text
    end
    matlabroot ... absolute path to MATLAB root folder
    os ... operating system, eg. win32 or win64
    In your case os=win32, that means you are calling 32-bit version of SimMechanics Link. I suppose that 32-bit version of SimMechanics Link can be used with 32-bit version of Creo 2.0, only. If you use 64-bit version of Creo 2.0, then you have to call 64-bit version of SimMechanics Link (os=win64 in protk.dat).
    Martin Hanak
