Problem With FEA
I want to FEA on a pin in a landing gear. When I went into mechanica, I accidentally checked off the box next to FEM mode. I didn't save and opened on another computer and it somehow I'm still opening in this mode. Now I don't know how to get out of this mode. Can anyone help?
    Hi Will! To get out of this mode , under FEM mode ,on the top of your toolbar select "edit" and click on "mechanica model setup" right at the bottom,it will bring you back to the mechanica box from which you will deselect the FEM check-box and click ok,from there you'll suppose to be fine i presume.Please try that and let me know,please. Regards, Olivier Mvudi
    Another hour after I posted, I finally figured that out. Thank you very much for your rapid reply!
