Mar 30, 2013 10:27 AM UTC
Proe wf5: data migration
We are migrating all pro e cad data to Siemens team center, We are facing issues ,
Any body can help????
regards,
Siva
    Mar 30, 2013 5:01 PM UTC
    TeamCenter is a handful. Exactly what kind of help are you looking for?
    It is best to have Siemens take you through the conversion. They can deal with issues as they come up.
    Apr 1, 2013 3:01 AM UTC
    Migrating PROE CAD data into teamcenter is my problem. I tried to create the instruction file using dry run option, but it showing some error ...
    ERROR ( 282.361): Original Exception pfcExceptions::XToolkitCommError
    Pro/TOOLKIT error in function ProSessionMdlList, error code -11
    J-Link method pfcSession::BaseSession::ListModelsByType
    com.ptc.pfc.Implementation.pfcExceptions$XToolkitCommError
    at com.ptc.pfc.Implementation.pfcSession$Session.ListModels(Native Metho d)
    at com.transcendata.cadpdm.pe.PEAllModelsCollector.execute(PEAllModelsCo llector.java:218)
    at com.transcendata.ipemsoaimport.BulkLoader.load(BulkLoader.java:3824)
    at com.transcendata.ipemsoaimport.BulkLoader.main(BulkLoader.java:4809)
    ERROR ( 282.361): Final Exception com.transcendata.cadpdm.CADException: Error w hile
    collecting all models.
    at com.transcendata.cadpdm.pe.PEAllModelsCollector.execute(PEAllModelsCo llector.java:291)
    ERROR ( 284.614): pfcExceptions::XToolkitCommErro
    r Pro/TOOLKIT error in function ProEngineerEnd, error code -11.
    J-Link method pfcAsyncConnection::AsyncConnection::End
    at com.ptc.pfc.Implementation.pfcAsyncConnection$AsyncConnection.End(Nat ive Method)
    at com.transcendata.cadpdm.pe.async.PEAsyncHelper.close(PEAsyncHelper.ja va:357)
    at com.transcendata.ipemsoaimport.BulkLoader.endPro(BulkLoader.java:4084 )
    at com.transcendata.ipemsoaimport.BulkLoader.main(BulkLoader.java:4834)
    C:\Users\4862>
