William, Just answered your question for an assembly, and suggested a Shadow Analysis. For something as simple as a block or sphere, I would, however, create a Sketch on an appropriate plane, and use the Create an entity from an edge icon to pick silhouette geometry. After you finish the Sketch, you can do Edit/Fill if you want to create a Surface representing the shadow. Afterward, you can hide the Surface, as necessary. David
thanks David, your create sketch worked well, especially because i did edit>fill, which i wasn't doing before. Shadow analyisis sort of works for my big assemblies but I haven't quite figured out what the "quality" "number" and "step" plot samples are, except that the answer varies when those parameters vary.
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
