Nov 9, 2010 1:12 PM UTC
Projected text
Does anyone have a good technique for projecting text on a cylinder? I've done the usual Edit>Project, but the results are not adequate because it still distorts the text proportions the further away from tangency the text curves. I need something that is accurate as I am going to use the text to laser mark some cylindrical parts.
TIA
    Nov 9, 2010 1:16 PM UTC
    Try Wrap instead of Project. But it will only work on parts not
    assemblies.
    Regards
    Sarah Ford
    CAD Designer
    Westwind Air Bearings
    Tel. 01202 627236
    Nov 9, 2010 1:40 PM UTC
    Toroidal bend will do what you want
    Nov 9, 2010 2:11 PM UTC
    Thanks everyone - Wrap did a nice job. Now I'll see if the laser can handle it.
