Oct 7, 2015 4:38 AM UTC
PTC Creo integration with Solidworks
I am attempting to try out Creo while working on the SAE international Baja competition car. I currently have a model of the frame of the car in solidworks drawn up with the weldments tool for the tubular steel. I was wondering if there is any way that Creo would be able to take the file from solidworks, and develop some sort of cut list for each individual tube member on the frame, giving me all of the angles needed to be cut on each tube. I was told that other teams from the previous years have used this method, and I figured I would try it out, it would be much faster than calculating each piece in solidworks.
Any help would be greatly appreciated!
-Nick
    Oct 12, 2015 4:10 PM UTC
    Hi Nick,
    If you are able/willing to send me a portion of the frame I could see what types of conversion would be possible.
    Also send me the tubing specs if you have them (ID, wall thickness, lb/ft, min/max bend radius, max/min cut length, etc).
    -Carl
