Feb 24, 2016 7:40 PM UTC
PTC_TENSILE_YIELD_STRESS
Hello
I get this message when I want to set the matter in Creo 3.0.
Or can one learn this information.
The PTC_TENSILE_YIELD_STRESS parameter is not defined.
The material is not valid.
Kind regards.
Denis
    2-Explorer
    Feb 25, 2016 5:11 PM UTC
    Are you using an elastoplastic material model?
    Feb 25, 2016 6:46 PM UTC
    Thanks for the reply,
    No,
    I simply wanted to identify the elastic steel.
    2-Explorer
    Feb 26, 2016 5:30 PM UTC
    So in the material definition box for the stress-strain response it says, "linear"?
    Feb 26, 2016 8:25 AM UTC
    Denis, please check if you have the stress-strain response set to "Linear".
    If that is the case, the system should not complain about yield stress.
    Mar 4, 2016 1:35 PM UTC
    I get this message at random times even with sensible material properties.
    It seems to occur most often when taking an existing material as a starting point, copying it and then editing the copy.
    I may only change the E and nu slightly but it insists that this parameter PTC_TENSILE_YIELD_STRESS is not defined.
    So I give up and define the material from scratch and the s/w is happy.
    I have been meaning to file a call for a while.
    Mar 6, 2016 3:10 PM UTC
    It even happens now and then when you define a new material. No idea what to do about it.
