ptcstatus
I can not see the licences that are in use when typing "ptcstatus" in a command file. The computer is indicating that it is searching but then the screen is empty. Is there a repair file or can I download ptcstatus again? Regards Ferry
    HI, if you have just upgraded from 2001 to WF uninstall 2001, it could still be looking for the old licenses. Or try run it from the apropriate BIN folder, should get the right server then. Ian H.
    Hello Ian Thanks! I've upgraded from WF2 to WF3. And now that you told me where to find the bat file, I can test it. It seems that if I double click the bat file in my explorer, it works. When starting cmd via run... and then type "ptcstatus" it does not work! Also in pro engineer, it does not work! But now I can flush again via the explorer menu so!! Many Thanks! Ferry
