May 14, 2014 1:41 PM UTC
publish drw and asm
Hi all!
is there a way to sepparate drw publishing from asm/prt? Our cadworker gets overwhelmed with cad doc publishing, so thinking of different ways to make use of multiple cadworkers.
Thank you,
D
    May 14, 2014 3:31 PM UTC
    Setup multiple CADworkers with multiple queues.
    I used to have 2 CADworkers with 4 queues, but since the upgrade to WC10, I have only put 1 CADworker back online.
    Dmi3U15-MoonstoneAuthor
    May 14, 2014 5:20 PM UTC
    In Reply to Dmitry Ushamirsky:
    Hi all!
    Thank you,
    D
    So, the reason i need to separate drw from asm and prt is that we are publishing drw to pdf using Adobe LiveCycle. If I just create another cadworker, than I will need to buy another license of LiveCycle. Trying to avoid doing this.
