May 4, 2015 2:20 PM UTC
Purging in 3.0
So how does it work now? Seems they change this with every release.
    Mahesh_Sharma
    22-Sapphire I
    May 8, 2015 4:16 PM UTC
    Michael,
    Common reason for this error is system environment variable "PATH", adding the bin folder location in Creo Parametric 3.0 in the value of Path variable should fix the problem.
    1. Start > Right Click on Computer and select Properties
    2. Select Advance System Settings > Select View tab under System Properties tab
    3. Select Environment Variable
    4. Select variable "PATH" under System variables and Edit
    5. Add path of bin folder under Creo 3.0\parametric in variable value (e.g. ;C:\Program files\PTC\Creo 3.0\<datecode>\parametric\bin)
    Mahesh_Sharma
    22-Sapphire I
    May 5, 2015 12:13 AM UTC
    Open System Window > Purge
    > After launching Creo, Open System Window can find under Utilities
    > In Part/Assembly/Drawing modes, Search for command Open System Window > Purge
    May 8, 2015 1:38 PM UTC
    that's how it use to work. now I get a "not recognized as internal or external command"
    Mahesh_Sharma
    22-Sapphire I
    Michael,
