Radius/Diameter dims
How do you create the radius and diameter dims?
    For Radius: Select the arc with single left mouse click and then use middel mouse click to place dim. For Diameter: select the arc with double click of left mouse and then use middel mouse click to place dim. where every you need Singh
    Amcare1-VisitorAuthor
    Thanks for the help!
