rcover a Parameter
Hello, How can i recover the name of the model (&model_name) in a parameter. I tried with the relations but it doesn't work. Thanks
    7-Bedrock
    I tried a one line relation : NAME=rel_model_name() and it works fine... Why did you create a string length parameter before ?
    That's works fine! Thanks a lot! regards
    Try these relations strlen=string_length(rel_model_name()) name=extract(rel_model_name(),1,strlen) where strlen is a "Integer" Parameter and name is a "string" Parameter
