Apr 13, 2011 7:01 PM UTC
Re: Dual Dimensioning in WF4
There is an option to show dual dimensions but I do not remember it. Also there is an sentence that you type into the options box to get a listing of all of the options available in ProE, can you help me with this? Any help is appreciated. Thanks!
    Apr 18, 2011 2:20 PM UTC
    Hello Gerald
    If you created your own dtl file, you can set it for every new drawing with configuration options (in config.pro):
    drawing_setup_file ...path_to_file\your_file.dtl
    pro_dtl_setup_dir ...path_to_file
    You can create your custom formats and set configuration options (in config.pro):
    format_setup_file ...path_to_file\your_file.dtl
    Note: in old drawings do you need set dtl file manualy (you can use Mapkey too or ModelCheck)
    Vladimir
    Apr 14, 2011 5:32 AM UTC
    Hello Gerald.
    Configuration option for dual dimension you must set in *.dtl file for drawing.
    dual_dimensioning
    List for options is:
    no* (deafault)
    primary[secondary]
    secondary[primary]
    secondary
    Do you can specify second dim with:
    dual_secondary_units
    mm*
    inch
    foot
    cm
    m
    Vladimir
    GRS1-VisitorAuthor
    Apr 18, 2011 1:33 PM UTC
    Thanks for the info on this.
    I realize that the Dual_Dimesion can be set in each drawing but I want it to be set in all drawings. Can you help me with this?
    Any help is much appreciated.
    Thanks, Jerry
    Hello Gerald
    Vladimir
