re: Retract Question(I Figured it out)
I figured out the problem with the retract.Each sequence has it's
own separate NC SEQ CYS.When setting up the operation I created a MACH CYS and also created a retract plane offset the Z MACH CYS.
I went into the operation and removed the retract plane.Every thing is working fine.Thanks for your reply's.In the custom dialog box
I removed the auto plunge,there is no retract to remove.
Rick
