RE: Summary: Symbol in a note or table no longer works - followup question.
All,
Has anyone tried using the technique below to put their company logo in
their format?
In theory, if I can put text into a table and call a symbol out using a
parameter in the text, then it should be able to display a symbol in a
table.
Presuming that one can control the position of the logo within the
table, then the advantage would be that I have the logo associated with
the table (which is copied in) vs. the .frm file itself. Thus, the logo
would move around with the table, and be removed when the table is
removed.
Does that sound doable? Has anyone tried this?
JD
