Recall: removing component from A simplified Rep
Malagi, Jayateertha (GE Consumer & Industrial, consultant) would like to
recall the message, "removing component from A simplified Rep".
    jaykm1-VisitorAuthor
    Hi All,
    This is fairly simple but I am at a loss to figure out how to do it. There
    is a simplified Rep of an assembly in which I need to remove a component
    from that Rep.
    I used the definition: "Exclude component" but now I am unable to find a
    means to remove this component from the rep. I use Pro/E 2001.
    Any advise?
    Thanks in advance,
    Jaya
    Hi All,
    I found one way to do it easily using Model tree-> Columns
    add/remove-->Simplified Reps--> Select your rep and edit as needed.
    Thanks!
    Jaya
