Redirecting output of proi.log files
  • February 28, 2008
  • 0 replies
  • 361 views
per: <u>https://www.ptc.com/appserver/cs/view/solution.jsp?n=/117891.htm</u>
i can't seem to get this to work properly. does the environment variable need to be a system variable? also, should the path be in quotes to accept the spaces?
any help is appreciated.
Ed Lee
Sr. Designer
