Oct 21, 2015 11:57 AM UTC
Reflection analysis
what is the specific use of Reflection analysis?
18-Opal
Oct 21, 2015 7:00 PM UTC
Hi Vishal,
You can find more information on this subject in the Help Center:
To Display Curve Reflection
Example: Curve Reflection
Amit
Oct 21, 2015 9:09 PM UTC
Vishal,
This may be helpful.
Surface Reflection
vpatel-41-VisitorAuthor
Jan 18, 2016 9:07 AM UTC
Thanks Ruben.
18-Opal
Jan 20, 2016 8:40 PM UTC
Hi Vishal,
Please mark a response, that you felt helped answer your question, as the Correct Answer.  That will help close the loop and provide a solution for other users with a similar query.
Amit
