Relations.
Associates,
I have a user that wants to make a series of dimensions from
different features equal to the same value (IE. d1,d12,d33,d744=50). Does
anyone know if this can be done with relations and what the syntax would
be? Thanks.
Dave
    I have the same question does anyone have a way to write this beside individually?
    d17d18d19=d20
    In other words I want 3 dim to equal 1 other without writing them on separate lines!
    Not like this
    d17=d20
    d18=d20
    d19=d20
    Any ideas?
    Thanx
    Associates,
    be? Thanks.
    Dave
    I do not think that is an option.
    Why would you want to have that many dimensions equal to another instead
    of creating a parameter that spells out what that information is and then
    put the dimensions equal to the parameter?
    For example:
    d17 = general_radius
    d18 = general_radius
    d19 = general_radius
    d20 = general_radius
    The reasoning is that the design intent is more clearly communicated.
    The reason I can think to not allow multiple dimensions equal to the same
    variable (dim, parameter or otherwise) is what happens to the relation
    when one of those dimensions goes away?
    Brian S. Lynn
    Technical Coordinator, Product Engineering
    FV_01
    Hello all,
    If someone really wants it the functionality is available through either J-Link-WF4.0 or Pro/Toolkit ( 2001 and up). There is an example in each respective manual of how to make a customized relation function.
    The chapters '<u>Adding a Customized Function to the Relations Dialog Box in Pro/ENGINEER</u> ' in WF4 J-Link user guide and in Pro/Toolkit User Guide explain the process and provide an example.
    HIH.
    Feliks.
    In Reply to brocade gainz:
    d17d18d19=d20
    Not like this
    d17=d20
    d18=d20
    d19=d20
    Any ideas?
    Thanx
    Associates,
    be? Thanks.
    Dave
