8-Gravel
Oct 25, 2016 8:42 PM UTC
Relations statement to identify even or odd numbers.
I am trying to write a relation that goes something like this...
IF
Parameter = even number
dimension_x = .05
ELSE
dimension_x=0
ENDIF
I cannot figure out how to get Creo to tell if the Parameter (which is a integer type) is an odd or even number.
Any thoughts would be greatly appreciated.
    KenFarley
    KenFarleyAnswer
    Oct 26, 2016 10:59 AM UTC
    To do "int" you either have to use "floor" or "ceil".
    The easier thing to do is use the "MOD(numerator, divisor)" function. To find out if a number is odd or even, it's something like
    IF MOD ( number, 2 ) == 0
      /* Do this stuff if even.
    ELSE
      /* Do this stuff if odd.
    ENDIF
    Oct 26, 2016 8:16 AM UTC
    Without checking exactly what the syntax would be in Relations, the usual approach is:
    if( x/2 = int(x/2) ) then it's even
    Is there an int() in Relations?
    KenFarley
    KenFarley21-Topaz IIAnswer
    ELSE
    ENDIF
    Oct 26, 2016 11:03 AM UTC
    Ah yes, that's a little neater.
    I believe INT is usually equivalent to FLOOR (i.e. 'take the INTeger part', not 'round to nearest integer').
    KenFarley
    Oct 26, 2016 12:31 PM UTC
    Yeah, to round things I usually "cheat" by doing something like floor ( number + 0.5 ). It's kind of weird the functions that are included and more importantly not included. I'd love to see a "real-to-string" function, so I wouldn't have to use multiple lines of code to do the same thing. It would also be kind of cool if there were some sort of ability to define our own functions. That would really make things simpler for me.
