Release datecode
Does anyone know what the difference between datecodes are ( like C000, F000, M000)?
Denis
    Cxxx are preproduction releases
    F000 is the initial production release
    Mxxx are maintenance releases of an F000 release
    Pro/E can be installed from any CD set, Cxxx, F000 or Mxxx.
    Windchill may require a mix of F000 CD's and the Mxxx build that you are
    installing.
    Ben Loosli
    Sr IS Technologist
    Engineering Automation Systems
    L-3 Communications/Integrated Systems
    Waco, TX 76715
    254-867-4069
