Nov 15, 2012 9:11 PM UTC
rename a Column in Creo
Can someone tell me how to rename a column in Creo? it's been 4 years since I've worked with Pro.
Will
    Nov 15, 2012 9:48 PM UTC
    To better describe my situation, I'm trying to rename a family table column on the drawing side (in particular the common name) and I do not remember the code to do so.
    Nov 18, 2012 12:15 PM UTC
    Hi.
    How did you made the table in the drawing? Repeat region or simple table?
    May 31, 2013 9:00 PM UTC
    Michael,
    Change the dimension symbol to a letter or text, the letter or text will show on the column in the drawing.
    Ken
    Jun 3, 2013 1:46 PM UTC
    Hey Ken,
    I know about that renaming capability. We do a lot of family tables and BOMs on the same drawings. When I want to link the BOM to the family table so that "ITEM 2" for example could be a heading for a family table component column title to link that part to the BOM, I have to minimize the text that Creo automatically puts there. I believe at my last company they had a basic formula in the relations table that would fix that but I can't make it work because I can't remember how it was done. But it keeps everything parametric.
    Mike
    Jun 3, 2013 2:14 PM UTC
    Mike,
    Thanks for the info.
    My question in Creo 1 (M050) is to remove a column on the drawing. Creo 1 (M040) works when using a filter.
    Ken
    Mar 28, 2014 12:27 PM UTC
    The tables we use were created from a repeat region.
