Mar 17, 2015 1:36 AM UTC
repaint problem
I´m using Creo from a month ago, at the beginning it works O.K, now, I have to repaint the screen over and over again because the dimensions and things like that, stays in the graphic windows,
Mar 17, 2015 2:25 AM UTC
Have you updated your graphics driver between the time it worked and when it stopped working properly?
Mar 17, 2015 2:20 PM UTC
Unfortunately no, how can I do that?
Mar 17, 2015 4:28 PM UTC
It is a good thing that you didn't. Normally that would be the 1st culprit.
If you have an academic version of Creo, please use the academic support page
PTC Academic Program | Academic Technical Support | PTC
If you have a full license and are still under maintenance, please file a support case.
