Apr 15, 2014 6:18 AM UTC
replace a string content through relations
Hi everyone,
I need your help to replace a string content with the help of relations.
Ex. If the file name is "Bracket_Housing" then i need the description to be "Bracket Housing".
I use description=rel_model_name() in relation but the output in descriotion with "_" symbol is odd.
My component description is always the file name but without the "_".
I want to eleminate the "_" in the description.
    GucioAnswer
    Apr 15, 2014 7:37 AM UTC
    you can use simply relation
    POSITION=Search(FILE_NAME, "_")
    LENGTH=String_length(FILE_NAME)
    NAME=extract(FILE_NAME,1,POSITION-1)+" "+extract(FILE_NAME,POSITION+1,LENGTH-POSITION)
    So if you define in a FILE_NAME parameter "MY_PART" as a value - you will receive "MY PART" as a value of NAME parameter.
    problem begins when your FILE_NAMA contains more than one "_", because Creo relations don't use loop . In that case you have to write relations that will check is there are more "_".
    In below example, I assume that FILE_NAME=FIRST_SECOND_THIRD_DESCRIPTION (3x"_")
    EXAMPLE:
    if Search(FILE_NAME, "_")!=0
    NAME=extract(FILE_NAME,1,Search(FILE_NAME, "_")-1)+" "+extract(FILE_NAME,Search(FILE_NAME, "_")+1,String_length(FILE_NAME)-Search(FILE_NAME, "_"))
    if Search(NAME, "_")!=0
    NAME=extract(NAME,1,Search(NAME, "_")-1)+" "+extract(NAME,Search(NAME, "_")+1,String_length(NAME)-Search(NAME, "_"))
    endif
    endif
    endif
    If value of your FILE_NAME parameter contains more than 3 "_" - add additional line that will replace "_" to " "
    endif
    regards
    gucio
    Gucio16-PearlAnswer
    EXAMPLE:
    endif
    endif
    endif
    endif
    regards
    gucio
    Nash1-VisitorAuthor
    Apr 15, 2014 9:24 AM UTC
    thanks .
    but what does
    if search(Name,"_")!=0
    signify
    Apr 15, 2014 11:36 AM UTC
    Becaues FILE_NAME is immutable, NAME parameter must be created. This relation check if in NAME parameter character "_" occurs. if YES (!=0) rest of relation is executed
    regards
    gucio
