Nov 27, 2013 2:29 PM UTC
Returning information back from an external program called by Smart Assy
Is it possible to return values back to the SA Application after calling an external program/method?
With the PLUGIN command, I know you can pass arguments to an external program
    Nov 27, 2013 3:21 PM UTC
    I'm guessing that you can't do that directly, but you could probably have the program you are calling via PLUGIN store data in a text file or perhaps a spreadsheet and then read that data back into SmartAssembly.
    Design well!
