Nov 30, 2015 8:25 PM UTC
Rhino 3D files to Creo Parametric?
Hello everyone,
I am getting some models created by Rhino3D, in case i need to further modify the parts, i would want to do it in Creo Parametric.
My question is, what kind of file (i.e. file extension) should be exported from Rhino3D to best compliment Creo ? Hope someone
who has worked on Rhino share some experiences to me!
Thanks !
    Dec 1, 2015 2:53 PM UTC
    you can import rhinoceros files to the Creo Parametric. Basic license of Creo 3 supported this. Your model or assembly will be looks by surface models only but you can create thick and you can doing modifications of course..in flexible modeling for example...or you can save your rhino models like a IGS formats, it is your choice. I have  some rhino models and i can imported it in creo without problems.
