Round/ Chamfer Propagation
Hi all
a round or a chamfer is created slecting a single edge as ref, using transition stopped it midway of the ref edge, another round or a chamfer created using the remaining edge as ref, two conditions normally arise
a) if the size of the later round/ chamfer is small, two seperate features apear
b) if the size of the later round chamfer is larger than the first...it propogates through! the first round/chamfer
the second case is the one which at times fails also!!
can anyone enlighten me as to what is reason behind it
thanks in advance
Amer
College of E&ME
using WF 3.0
