Apr 3, 2008 4:54 PM UTC
Run mapkey from a trail file
OK, I've searched the archives long enough with no solution.
How do you run a mapkey from a trail file?
Vaughn McDaniel III
CAD/PDM Administrator
Windsor Industries
A member of Kärcher Floor Care
Englewood, CO
303.762.1800 x187
    vmcdaniel1-VisitorAuthor
    Apr 4, 2008 3:01 PM UTC
    Is there are context I can use in a trail file to call a mapkey? e.g
    #<mapkey_name>.
    Or am i stuck putting all the commands in the trail file.
    Vaughn McDaniel III
    Windsor Industries
    Englewood, CO
    303.762.1800 x187
    "Vaughn McDaniel" <->
    04/03/2008 10:54 AM
    Please respond to
    To
    cc
    Subject
    [proecad] - Run mapkey from a trail file
    Vaughn McDaniel III
    Windsor Industries
    Englewood, CO
    303.762.1800 x187
    Apr 4, 2008 3:12 PM UTC
    This trail file does nothing but run the mapkey 'lbd'. It's from 2001, but still works up to WF3. I haven't tried WF4 yet.
    I use this to run a specific mapkey (loading a specific config file) at Pro|E launch. I've made several copies of this and simple changed the 'lbd' to another mapkey sequence and it runs just fine.
    !trail file version No. 1151
    !Pro/ENGINEER TM 2001 (c) 1988-2001 by Parametric Technology Corporation All Rights Reserved.
    ~ Select `main_dlg_cur` `MenuBar1` \
    1 `Utilities`
    ~ Close `main_dlg_cur` `MenuBar1`
    ~ Activate `main_dlg_cur` `Utilities.psh_util_macros`
    ~ Select `mapkey_main` `list_mapkeys` \
    1 `lbd`
    ~ Activate `mapkey_main` `RunButton`
    Doug Schaefer
    Apr 18, 2016 3:39 PM UTC
    Doug I am trying to create a file open then run a mapkey from a batch file. When I do this I get a ton of extra stuff, not sure what I can delete and what I cant. Any suggestions?
    Apr 18, 2016 4:12 PM UTC
    This is a very old post - note the original is dated 2008.
    That said, I'm still using this same method, and likely the same trail file.
    I created the trail file by starting a new session and typing the mapkey I want to run.  That's it, don't close Creo or do anything else.  Go to your trail file folder and find that trail file and copy it.  Then, you need this line in your batch file to run the trail file when you start Creo:
    start "" "path/to/parametric.exe" path/to/trail/file
    I hope that helps.
