Nov 23, 2010 5:50 PM UTC
Save a Copy as edz in ProE creates a .log file
Is there some setting, perhaps in the ProductView, that will turn off the creation of the .log file when I Save a Copy as edz in Pro/E?
    Nov 24, 2010 9:17 AM UTC
    Hi
    I've seen pro-e does the same thing if you export a drawing as dxf.
    I use this often to send a laserdrawing of a part.
    Anyone?
    Regards
    Chris
