Nov 24, 2014 8:48 AM UTC
Save a CREO 3.0 model as a CREO ELEMENT/PRO model
Is it posssible to save a model as CREO ELEMENT/PRO from CREO 2.0 ??
Regards
    andy2Answer
    Nov 24, 2014 1:28 PM UTC
    Files are not backwards compatible for CREO.
    You can open earlier versions with later versions, but not the other way around.
    Nov 24, 2014 9:54 AM UTC
    Mathieu,
    it is not possible.
    Martin Hanak
    msauthier1-VisitorAuthor
    Nov 24, 2014 10:31 AM UTC
    And from CREO 2.0 ??
    andy21-VisitorAnswer
    Nov 25, 2014 9:36 PM UTC
    Using the GCRI tool you can open newer version models from Creo in older versions of CE/Pro or Pro/ENGINEER. This should provide the solution you need:
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34964&posno=1&q=gcri&nav=ptcproductgroups||creo||Product+Group||creo&source=Search
    Mahesh_Sharma
    22-Sapphire I
    Nov 28, 2014 5:34 PM UTC
    Mathieu
    It was discussed in one of the earlier post http://communities.ptc.com/message/254637#254637
    This post may give you some more information about this.
