Thanks WoHo. When I get the full version, will the DXF output file then be compatoible with AutoCad, if that's what my tooling provider uses? Also, will there be a way of increasing the size of my design, either in OneSpace or in AutoCad, maintaining everything proportional to my design?
A
Anonymous
Sep 26, 2007 11:49 PM UTC
The DXF output was implemented with the intention to provide useful data exchange particularly with AutoCad, so yes, you should be able to transfer your data. As WoHo outlined in the ""I goofed up"" discussion thread, you can fix your dimension problem by using the scaling functionality in OneSpace Modeling (PE). Hope this helps, Claus
