Dec 14, 2006 5:56 PM UTC
Save As (Exporting to obj)
I have with succes converted many parts to obj files. The result is very nice. I have problems with some parts, nothing is written to the output file. How can that be? ProE just writes: "0 triangles have been written in output file", but why?
    Dec 15, 2006 8:17 AM UTC
    Hi Could it be because non-solid parts are not supported? This is the case with STL export. Thomas
    Dec 15, 2006 4:39 PM UTC
    Yes that could be! Is there a way to make these parts solids?
    Dec 18, 2006 8:45 AM UTC
    It depends on the parts. If all surfaces meet, then solidify will do the trick. Otherwise: Thicken from Edit menu can make solid shells out of surfaces.
