Save deformed state
Hi all
Does anyone know if it's possible to save the deformed state of a static analysis?
I may be dreaming that I've seen it done...
Alternatively, is it possible to determine the new volume?
Rui
    Hello Rui,
    I believe you can perform an export of a vrml in the Mechanica results
    window. From
    there you can import that vrml file into ProE. If I remember correctly it
    is just a surface
    model.
    Hope this helps,
    Steve
    Stephen Seymour, P.E.
    Principal Engineer
    Seymour Engineering & Consulting Group, LLC
    www.seymourecg.com
    Thanks to Steve.
    This is exactly what I had seen and was looking for. In reality it's a facet model, less useful than a surface one :(
    Rui
    On 22.10.
