Scewdriver clearance
I have an off the wall question.
I need to add a clearance hole just large enough for a #2 Phillips
screwdriver shaft in one of my parts. The head of the screw does not
need to pass through the hole, because I am using a captive type screw.
But I want the exposed opening to be as small as possible.
Does anybody know the diameter of a #2 Phillips screwdriver?
I have tried Google and Yahoo searches with no luck.
Douglas A. Green
Thales Avionics Inc. - Inflight Systems
Sr. Mechanical Designer / MCAD System Administrator
58 Discovery Irvine CA 92618-3150
Phone 949 790-2874
Mobile 714 815-5960
www.thalesgroup.com <http: www.thalesgroup.com=" aerospace=" home=">
This e-mail message is for the sole use of the intended recipient(s) and
may contain confidential and/or privileged information. Any unauthorized
review, use, disclosure or distribution is prohibited. If you are not
the intended recipient, please contact the sender by reply e-mail and
destroy all copies of the original message.
