section thicken ??
It probably is right in front of my face, but I don't see it
Where did section thicken go ?
I'm on wildfire 3.0 M110
    What Liek was referring to was the ability to *show* the thickened
    entities in your sketch, and dimension to them. This was quite useful
    for sections where your design intent was to drive the dimension to a
    piece the thickened edges. Sketcher would show the thickened edge in
    dotted lines.
    That feature is not available now; the thickened profile is only
    viewable after you exit sketcher. You can just use relations instead,
    but that's a bit cumbersome. What's worse, you can't even use a section
    relation to accomplish this because the thickness of the section is not
    an available dimension in the sketch.
    Best Regards,
