Feb 25, 2012 6:20 PM UTC
see pic
see pic
if i change connection from cylinder to pin it will show its name but not in cylinder connection why?? unable to find.....
    Mar 26, 2012 4:45 AM UTC
    Hi
    If you have enabled Enable regeneration value; then you should be able to see the value by edit option.
    Right click on the second part (of the cylinder connection)and select edit as shown in the picture.
    Regards
    K.Mahanta
    Feb 27, 2012 11:28 AM UTC
    still waiting
    Mar 23, 2012 7:17 PM UTC
    I know in Creo Pro E 5.0, you can right click on the feature, select edit, and then select and right click the dimension and choose properties - this will show you the name and also allow you to rename it.
    Mar 26, 2012 4:02 AM UTC
    thanx 4 ur rply but problem is it do not show dimension (in edit mode) which im pointing in pic..
