Selection Highlighting
WF2, M220
I'm trying to put together a rather large assy simply to get a view comparing 3 of our client's products.  I'm using simplified reps, but what's slowing my down is Pro|E pausing to highlight every edge of the subassy (an entire product) when I pick it.  I've turned off the highlighting in the model tree for when I pick there, but that doesn't kill all of it.  How do I turn off these highlighting situation as well:
*     If I select items in a simplified rep in the view manager, they still highlight on screen.
*     If I pick items from the model tree and RMB and select modify, they then highlight on screen.  I simply need the dims to come up to I can change them.
There may be more, but that's what I've discovered.  It seems that when I pick an item from a list like the view manger or model tree, I know what I'm picking and being able to turn off that highlight will greatly speed up my work.
Keep in mind, this is NOT the pre-selection highlighting, this is the selection highlighting that I'm talking about.
Any ideas?
Doug Schaefer
