Nov 12, 2013 10:27 PM UTC
Set arrowhead style to "none" on 1 of 2 arrowheads in a diameter dim?
I used to be able to do this in CREO 1.0 by selecting the arrow I wanted to hide, right clicking, and selecting "arrow style," and it only changed the one arrow. I have not been able to do this in 2.0. If I change the arrow style it changes both arrows. Is there a different way to do this?
    James62Answer
    Nov 14, 2013 8:07 PM UTC
    It's still doable in Creo 2.0. The behaviour of notes is just a bit different. You need to click right onto the tip of one of arrows with RMB, and then pick Arrow Style from the pop-up menu. After that make your choice in menu manager, and click done.
    James621-VisitorAnswer
    Nov 14, 2013 8:45 PM UTC
    Very nice, Jakub. I would have never found that if I needed it.
    This must be like those hidden coins in the video games
    Nov 15, 2013 4:08 PM UTC
    Ah, yes. I remember those old adventure type of games where you had to click on things in a room just to pass into a next room. One could never tell which object is actually active in these rooms. The game always turned into some crazy clicking after a while.
