8-Gravel
Dec 10, 2013 9:39 AM UTC
Set display style to shading
Hello!
There is a possibility to set the display style of the model to shading?
Thanks, Lars
    Dec 10, 2013 9:57 AM UTC
    Hi Lars,
    You could set the config option "display" to "shade".
    In TOOLKIT this can be done with ProConfigoptSet.
    You will probably need to call ProWindowRepaint to
    update the display.
    Have never used this myself, but it should work.
    Frank
    Am 10.12.2013 09:39, schrieb Lars Ziegler:
    > Hello!
    > Thanks, Lars
    8-Gravel
    Dec 10, 2013 11:09 AM UTC
    Hello Frank!
    Thank you!
    That works perfectly!
    Greetings Lars
